A mechanical idiot installs Rizoma Class Retro Mirrors using Rizoma Bar Ends
I had a set of black
Rizoma Class Retro Mirrors from a previous bike that I mounted on my R9t. These are great mirrors. Much better view beside and behind the bike and much less vibration than stock. This set came off a bike I drove into the side of an SUV that turned left in front of me. Bike was totaled, I was dazed and confused and the mirrors had barely a scratch.
I mounted them using
Rizoma Bar Ends part number MA506X where X indicates the color. This is an easy process. Since I'm in the less mechanically inclined portion of our community, I'll explain the process in painful detail. You'll need the following:
Mirrors
Shims supplied with the mirrors
Bar ends MA506
Torx T55 bit
Medium strength loctite
Hand drill with 12 mm drill bit. Half inch bit would work as well but is larger than necessary. A drill press would be preferable but the results will look the same.
Metric hex key to attach the mirrors
The process is straightforward. Take the Rizoma bar ends, set aside everything but the actual aluminum bar end. Drill 12 mm holes in the bar ends. Remove the stock bar ends. Remove the loctite from the stock bar ends with denatured alcohol or goof off. Reapply medium strength loctite to the bolt. Attach the modified Rizoma bar ends with the stock R9t bolts. Attach the mirrors.
I've provided pictures below.
Here's the bar end with hardware.
You are only going to use the aluminum bar end piece. A black one is pictured here with the hole already drilled out to 12MM to be installed with the stock R9t bolt.
Once you've drilled out the hole, remove the stock bar end, clean the loctite off the bolt. Apply new medium strenth loctite and attach the Rizoma bar end with the stock R9t bolt. The outer end of the Rizoma bar end is recessed and the recessed area is deep enough to hold the head of the stock R9t bolt. The bar end will bind the end of the clutch side grip and that's fine because you probably don't twist that grip much. The throttle grip has a space to keep the bar end clear of the grip so a spacer isn't required. Lock washers might be a good idea but I didn't use them because the bolt is large and the bar end is aluminum so I figured it would bind them securely. After a 1,000 miles they haven't moved.
The mirrors definitely contact the tank if installed below the bar.
Here are a few (really bad) photos of the mirrors installed. Note that the previous picture showed a black bar end I had laying around and used to test fit the mirrors. I only had one black bar end though so once I worked it out, I ordered a full set which was on sale and happened to be gold. So the photos below show the bar end in gold. Love the gold or hate it but it makes it easy to see the parts in these photos.
The holes where the stock mirrors attached bothered me so I found a solution.
These are available in 16mm and 20mm lengths from Boltdepot.com The 20mm stand proud of the hole so I went with the 16mm. 18mm would be perfect but it's not available. The socket for the hex key is so deep that you are actually filling a hole with a smaller hole. My solution was to screw them in with my finger upside down. That way there's not a hole there. Removing them will require drilling a small hole in them so I can spin them out but that won't be a big deal. Here's how they look installed:
Hope that's helpful for anyone looking to install bar end mirrors using Rizoma hardware.
