There's a CRG mirror thread you might want to look into for more information.Helpful thread, going from Rizoma clip ons back to a stock bar and was curious if the CRG mirrors I have would work with the factory bolt/end. Good to know as long as I have a 12mm drill bit I should be good to go.
What’s the correct adapter kit?Yes you do need the adaptor kit. If I remember correctly the R9T bars use an M12 sized bolt.
How is that working for you???? Solid?I just installed CRG bar end mirrors using OEM hardware with no drilling or moving of controls. Solution: got three M12 lock washers that fit on the OEM bolt - when tightened, it creates just enough space for the mirror to clamp on while leaving a very small gap so that nothing snags on it. Seems to work ok and looks decent, let's see how long it lasts.
Yep, it’s working great. No issues at all. Solid and no noticeable vibration.How is that working for you???? Solid?
Did you have photos posted of the in-progress and final result? Can't see them in the post.A few of the members have installed bar end mirrors, and when asked how, they typically respond with not the most detailed info. I wanted to fix that. So, I did some research and found a inexpensive and easy way to install a nice set.
Tools needed: Drill, bench vice, Torx socket set, socket wrench.
These are the mirrors I used:
I decided on the BikeMasters as I wanted to keep a stock look by keeping the aluminum end trim, minimal modification, and dead simple bolt on design. And they are half what Rizoma's cost.
Start by taking out the bar end Torx bolt (T-55 size)
It might be harder than you expect to remove due to the factory applied loctite, but it will come out.
Unfortunately the mounting hole on the BikeMaster bar end mirrors is not large enough for the stock end bolt, so the next step is to widen it. I used a small vice to hold the mirror while drilling it out with a 1/2 bit. The metal is easy to work with, took less than 20 seconds.
Then reassemble. The factory bolt is more than long enough to hold everything in place.
Looks pretty good to me, and only takes 10 minutes from start to finish.
Sorry for the shitty garage photos, its snowing outside today![]()
What spacer did you use mounting the mirrors? wat did you use to bolt the 8mm bolt in to the handle bar?Barkbusters with Rizoma bar end mirrors
