241 - 254 of 254 Posts
Let me know if there's anything you need to know that might be in my Rider's Manual and I'll get it to you somehow. What year/ model is yours?
Reactions: BlitzSchnell
Thanks Mate, you’re a sweetheart. I bought the Haynes manual and so far it’s answered many questions I’ve had. If it doesn’t cover something I’m interested in you’ll be the first place I go to ask.
Be safe and stay healthy my friend. Can’t wait to ride again. Blitz
I bought a Battery Tender Jr. model for about $22. It came with leads and has worked good for me.
I have a 2017 Pure with over 16K miles and the original battery still seems OK.
Hi everyone,
I am relatively new to the forum and have had a look around the threads. I have recently purchased a 2019 Scrambler and am looking for a can bus trickle charger for battery maintenance and mostly for during storage in the winter.
I have been away from the motor scene for a few years hence was wondering which is the one to buy.
Many thanks
Out of pure laziness I have bought the original BMW.
But I suspect that on Amazon you can find proper alternatives and save money...
Inviato dal mio SM-A750FN utilizzando Tapatalk
Ok thanks. The BMW dealer offers me the original one for the can bus for € 132 but not sure if there were any better ones out there.
Hi @FlyBike, there are probably 2 chargers that members seem to buy more than most - Optimate 4 (you can get a canbus edition for our BMW bikes) or a BMW charger. There are others you can use too if you so choose. There is a big thread that covers chargers on the forum so I've moved your post there. Plus other threads exist too if you do a search. Have a read and see what you think.
Thanks BaldyDave for the response and moving it to the correct thread. Sorry!
No need to apologise mate, you are new here and it can take a wee while to find your feet.
I have had an Optimate 4 Canbus edition charger for my bike since I bought it in 2014 and have to say I think it does a great job. It plugs straight into the bike's accessory socket and works really well.
2016 R-nineT Classic + 1984 Kawasaki ZL900
I’m using this CTEK Powersport and it does the job straight through the CANBUS.
R nineT Classic 2016
Kawasaki ZL900 1984
OK sorry to be redundant, but I am about to connect the charging pigtail I have for my CTEK charger to the '17 R Nine T Pure. Attached is the overhead view, and you can see the CTEK pigtail ends CT+ and CT-, ready to attach to something.
For the red, do I go to B1 or B2?
For the black, my preference is to go to one of the two screws behind (bottom of pic) the box. That would be screws 3 or 4.
Your advice is needed. Thanks.
Personally, I'd connect the pigtail direct to the battery, which sits under the back of the tank, only a few inches lower than where you intend to connect now.
Not prepared for tank removal.
@Shortfinger CT+ can connect to either B1 or B2, they are both connected together anyway via the metal band that runs beneath them!
CT- is probably best at 3 or 4, just make sure you have the ring at the bottom closest to the frame, and as I did, scratch a little bit of the paint away underneath the ring connector to be sure of a solid earth point. So to elaborate, this puts the connector underneath the strap mounting tang.
You could also place the CT- at 1 or 2, but be sure you can get it mounted on the frame. I don't remember what's under the alloy sideguards, but if the screw does go into the frame, then that's just as good a place.
Cheers
