1 - 7 of 7 Posts
BMW R Nine T Specifications
Engine
Type: Air/oil-cooled flat twin ('Boxer') 4-stroke engine, two camshafts and four radially aligned valves per cylinder, central balancer shaft
Bore x stroke: 101 mm x 73 mm
Capacity: 1,170 ccm
Rated output: 81 kW (110 hp) at 7,550 rpm
Max. torque : 119 Nm at 6.000 rpm
Compression ratio: 12.0 : 1
Mixture control / engine management: Electronic intake pipe injection
Emission control: Closed-loop 3-way catalytic converter, emission standard EU-3
Performance / fuel consumption
Maximum speed: over 200 km/h
Fuel consumption per 100 km at constant 90 km/h: 4,5 l
Fuel consumption per 100 km at constant 120 km/h: 5,8 l
Fuel type: Unleaded fuel, octane number 95-98 RON (rated output at 98 RON)
Electrical system
Alternator: three-phase alternator 600 W
Battery: 12 V / 14 Ah, maintenance-free
Power transmission
Clutch: Single dry plate clutch, hydraulically operated
Gearbox: Constant mesh 6-speed gearbox with helical gear teeth
Drive: Shaft drive
Chassis / brakes
Frame: four-section frame consisting of one front and three rear sections, load-bearing engine-gearbox unit, removeable pillion frame for single ride use
Front wheel location / suspension: Upside-Down telescopic fork with 46 mm diameter
Rear wheel location / suspension: Cast aluminium single-sided swing arm with BMW Motorrad Paralever; central spring strut, spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable
Suspension travel front /: rear 120 mm / 120 mm
Wheelbase: 1,476 mm
Castor: 102,5 mm
Steering head angle: 64,5 °
Wheels: Spoke wheels
Rim, front: 3.50 x 17"
Rim, rear: 5.50 x 17"
Tyres, front: 120/70 ZR 17
Tyres, rear: 180/55 ZR 17
Brake, front: Dual disc brake, floating brake discs, diameter 320 mm, four-piston radial calipers
Brake, rear: Single disc brake, diameter 265 mm, double-piston floating caliper
ABS: BMW Motorrad ABS
Dimensions / weights
Length: 2.220 mm
Width (incl. mirrors): 890 mm
Height (excl. mirrors): 1.265 mm
Seat height, unladen weight: 785 mm
Inner leg curve, unladen weight: 1.760 mm
Unladen weight, road ready, fully fuelled 1): 222 kg
Dry weight
Permitted total weight: 430 kg
Payload (with standard equipment): 208 kg
Usable tank volume: 18 l
Reserve: app. 3 L
believe me, that amount of power will be fine for this bike. I have the very same motor in my 2011 GS adventure and it does just fine with my sidecar rig which is infinitely heavier
Reactions: Markan and 9T33
Discussion Starter · #5 ·
now that is one sweet setup and one very nice dog, clearly we can see he/she loves being in the side car!
anymore pictures of this toy of yours?
1 - 7 of 7 Posts
