You can also use the R1200GS (>2009 to 2012) model maps as same engine and heaps of maps online for various configurations of intakes and exhaust
Did you tried them before Roadrunner?
No, I don't have a PC5, but the DynoJet agent told me they would work just fine as other than the muffler the engines are identical.Did you tried them before Roadrunner?
You need maps between 2009-2012 here: Welcome to Power Commander Motorcycle Fuel Injection Tuning ModuleHumm, ok. I check the maps they have for the r1200gs and they have from 2007 to 2009. I open them and compare betwen the 2. They have total diferente values in the tables...
Any experience with Dual Autotune?
Yes... and any issues? Did you remove the exhaust butterfly?
Can you comment a bit more on this? Theoretically the DynoJet PC5 should work the same as a reflash, no?Flash tunes are better than piggybacks.
Google it and make your own decisionsCan you comment a bit more on this? Theoretically the DynoJet PC5 should work the same as a reflash, no?
I'm not interested in a debate either. I would however appreciate if you can share any pros and cons with each solution.Google it and make your own decisions... I really don't want to get into the debate
What @rettek said above.I'm not interested in a debate either. I would however appreciate if you can share any pros and cons with each solution.![]()
Your chart
All manufacturers quote power and torque as per output at the crank, not the wheel. Dyno's typically measure power put to the ground, not the crank.2014 BMW R Nine T
I have installed the Remus Headers, Remus Hypercore Muffler and a PCV. I had a local shop tune my bike on the Dyno and put a custom tune on it. My tech said the bike came in with 90 HP and left with 102.61 HP at 78.14 lb/ft after the tune....
The bike is rated at 110 HP with 88 lb/ft torque from the dealer.....I am confused!!!!
The tune smoothed out the power, but I don't know if I like it, I liked the snappier throttle response..........the base tune from PCV was quite good.....
The exhaust note with the Hypercore is ANGRY and loud!!! I was under the assumption that there was a removable baffle, but there is not.........
I have attached my Dyno Results for review, sorry for limited visibility.....
Q's
Is there loss of HP calculation in the 'Dyno' testing procedure?
I figured I would be up around 120+hp......why not?
Is the 110 HP stated from BMW different than reality of RWHP?
Does anyone have a custom tune for these same upgrades I have?
Thoughts on an Auto Tune Kit, another $400+!?!?!?!?!?
Does the PCV allow you to extend the max speed?
Any warranty hazards to worry about?
Random, does a K1300 BMW rear rim fit on a Nine T?
Love this bike!! I've never seen another on the streets where I live or at any bike night!!!!!!
