What is the best method to remove the reflectors from the forks ?
Heated gun then use a fishing line to skim through then use 3m specialty adhesive remover if you can get your hands on some. If not wd 40 or even gasoline works.What is the best method to remove the reflectors from the forks ?
warning on the 3m adhesive remover.Heated gun then use a fishing line to skim through then use 3m specialty adhesive remover if you can get your hands on some. If not wd 40 or even gasoline works.
It's true. These reflectors were put on after a run to the hardware store for double sided tape. They peel right off. Made the feds happy.they are held on with double back tape, come right off with thumb and forefinger...then rubbed the residue off with a finger - can't tell they were ever there....
Some well placed retro-reflective 3M tape in the right spots is way more effective, and almost invisible during the day.I would not mind finding some in white to replace the orange ones with
That's all I did too. Just slowly pulled outward on the reflector, and it peeled itself away with no tape left on the forks. Cleaned off any gummy residue with the same sticky tape left on the reflector. Just dabbed it over the residue and it lifted right off.they are held on with double back tape, come right off with thumb and forefinger...then rubbed the residue off with a finger - can't tell they were ever there....
