If anyone is inclined to humor me and try this test I have been running on YOUR bike, I would be interested to know the outcome:
I have the tank up and the fuel pump disconnected so I can clip directly to the battery, but that said, I get the same results if I jus take the seat off and clip to the positive bolt at where the seat meets the tank and the negative bolt on the underside of the right head.
1. With the bike cold, preferably over night for the first test, I see the voltage.
2. I insert the key and, watching the voltmeter, turn to on- I do NOT touch starter button.
3. Watch the gauges cycle, hear the fuel pump and flapper servo (if you still have it) cycle, then wait 5-10 seconds after all is quiet, watching the meter.
4. Watching the meter, turn the key to off, and pull it out to make sure. At exactly 1 minute after turning key off, hear/feel servo and main relay open, voltage jumps, and then slowly rises back to resting voltage, within about 1 minute.
5. Repeat 5x, not waiting overnight between each test, just a few minutes, long enough for the battery to rise back up resting voltage of say 12.7 to 12.9
What I am interested in knowing, is the range of the voltage dip. On the first test, mine starts at 12.8 and dips to 12.4 or 12.3. By the 5th test, mine starts at 12.7 and dips to 10.5 volts.
