41 - 46 of 46 Posts
2015 Classic
Hi, so I’ve bought the type 4 Ledperf headlight which has internal indicators. Lovely looking light and box, no instructions... Any idea on how to hook up the indicators? Not sure what to connect the red, black and grey wires to....
2018 R Nine T Racer
These are for the indicators an running lights I guess ?
Black is normally mass, red is positive and the grey must be the running light.
So tap the grey into the white wire of your bikes harnas connected to the headlight, the mass into a black wire from your harnas or on a point on the chassis and the red to a plus from your indicators.
Verzonden vanaf mijn iPhone met Tapatalk
Signals will likely not work as blinker but as DRL only. On mine, the black is ground and the red was white DRL lights, the grey would make the DRL yellow. Both internal side lights are connected as one and can't be used as signals. If it's different on yours, then you are missing a wire. You would need ground, DRL, signal left, and signal right, making it 4 wires.
2015 Classic
Thanks Ghostrider, Alvidtk. That makes sense, but the ad definitely gives the impression it should have turn signals:
134415
41 - 46 of 46 Posts
