Here is what I did for the micro switch.
I didn't want to cut the OEM plug from the harness so I hacked the female side which is the OEM microswitch.
There is a type of semi-hard WAX that you will need to remove.
Start with a pick and slowly remove whatever you can remove from the two holes.
Then you will need to pry and remove the switch itself.
The switch will break but who cares. All you need is the female connector.
Pry-Remove-Cut until you start to see the connector pins.
Dig around the two pins you need so you have enough metal for soldering.
Cut the surrounding enclosure that has a rectangular shape (you don't need it).
Remove the Micro Switch from Magura master cylinder.
Cut the two wires of Magura switch to the required length.
Solder them to the OEM female plug.
Don't forget to shrink tube each soldered wire.
At the very end you can put a very big shrink tube to cover everything but I used for electrical tape because I don't have a shrink tube that big.
This works very well if you want to save your original wire harness.
