Bled and installed the HC3 levers today. Used blue Magura blood from the bike shop. Let me say that while this install isn’t hard, it’s EXTREMELY tedious if you get air in your lines because of the ABS system. I tried a vacuum hand pump, that made things worse, then did a caliper-to-master bleed, was better, then had a friend come over and use a compressor vacuum system. It feels SIGNIFICANTLY better than stock, but the brake isn’t as rock solid as I would have expected, so I have an appointment with the dealer to bleed it on Thursday just to be certain all the air is out (anybody who has seen the pump system a dealer uses to bleed brakes know there is zero chance of air being in the system if done correctly.)
Also, because I didn’t want to cut the factory harness, I cut the female end off the oem clutch switch connector, trimmed up the connector so it would be as small as possible when heat shrinked, and plugged it in.
In the end, I would have gladly paid the dealer one or two hours of labor to install and bleed the brake and clutch. It was satisfying, yes, but bleeding brakes suckson a bike with ABS
