You don't really need a temp gauge because it doesn't get hot? I guess you don't need oil pressure or charging system warnings either. After all, it's a BMW! Next we won't really need a warranty.
Can someone post a pic of oiltemp in bars? This is completely wackoYou will have beautiful red-hot bends if you let a boxer run 15 mins in your garage, for sure. But I said, as long as it's in motion you will hardly ride it too hot. Under normal circumstances the air-cooling or how the exact expression is, airflow cooling is sufficient to keep the engine in a good operating temperature range. Only exception perhaps if you live in Death Valley.
On the other hand, can you tell me what you see on the oil-temp gauge? What do 4 bars tell you? And what do you know more when you see 6 bars? That the engine oil is 2 bars hotter? Did you ever think about why it doesn’t get hotter than 6 bars?
Oil pressure is much more interesting. The two valve R 100 RS had an oil pressure gauge, not to mix up with a little red lamp, that begins to glow, when the oil pressure drops under a certain value.
I stick on it: An oil temp gauge (with bars, not with degrees) and tank gauge are not necessary to survive...
Exactly, I also can hear when Elsa is thirsty... with my 5 former GS+GSA's I could tell when to fill oil in between 2 inspections just by the sound of the engine. One of them consumed 1 liter per 2500 k...
oh oh oh shame shameExactly, I also can hear when Elsa is thirsty
Here's a pic from the oil gauge (the 4 bars on the left side), sorry... a little wiggly
Pretty cool!They are here! $68
eBay item number: 121780324206 feh
eBay item number: 111790701468 cel
... interesting ... but that eBay item number is of no use at all, please post the web address (copy from your browser bar) ... thanksThey are here! $68
I guess it wont't be sheared off as it is on top of the valve cover. But if it drops you have other things to repair than the gauge.Just wondering what will happen if the bike drops and the temp gauge is sheared off? Since it seems to stick out a fair bit
I was thinking more along the lines if it shears off, and now there is nothing to cover the hole. Bike would not be rideable without having engine oil shooting out.I guess it wont't be sheared off as it is on top of the valve cover. But if it drops you have other things to repair than the gauge.
I have one of these , I have just got my new replacement R9T after a big crash , Bike written off both cylinders scrapped one side the valve cover distorted so oil leaked from the gap where the gasket should be sealing ! oil temp gauge not even scratched !I was thinking more along the lines if it shears off, and now there is nothing to cover the hole. Bike would not be rideable without having engine oil shooting out.
Other things to repair is not an issue....anyway just a hypothetical thought.
