1 - 9 of 9 Posts
Does anyone know what the combined weight saving is by removing the pillion seat & sub-frame please?
That's 22lbs. With a slip on exhaust, wow. 30+ lbs weight savings? Takes a 210lb person and makes them perfect for the stock spring setup???
2018 BMW R nineT
That's some good weight savings indeed and I occasionally switch to that config, pillion removed. However, the weight savings here are in the wrong end, IMHO. I feel that the R nineT is already light on the tail and heavy on the nose, causing the occasional instability in the rear and at low speeds, causing it to sink in to the inner side of the bends, particularly while maneuvering at very slow speeds, like u-turns. Heeeeeavy engine....
Bolts extra...
Factor in an additional weight for a new exhaust hanger and a hump to replace the seat and I think you'll get a nett saving of 7lbs.
Makes it a super clean design though :cool:
i agree, definitely not a wheelie bike.
1 - 9 of 9 Posts
