Worked for a my 2019 Pure if that helps.Any idea if the parts numbers will work for the 2020 Pure?
Hi thereI received mine for the Urban GS and I have the same part numbers, however they still lay on my desk, waiting for being fitted.
Those are the part numbers I used when I ordered the rev counter and support bracket for my Urban.Hi there
Can anyone confirm that this is the right parts for my Urban View attachment 135318
And did it fit nicely with the clutch cable and all other wiring on the outside of the clocks or?Those are the part numbers I used when I ordered the rev counter and support bracket for my Urban.
cool thanks for your inputAbout that I don't remember where, but there is a clear indication in the forum on where to recover some slack for the cable. Check on the left side, the clutch cable comes out from under the battery case. There's a clip on the frame that you can unclip the cable from to get additional 3-4 cm slack. You should be able to push it up to the triple tree from there, if it's to stiff, you may need to work its path out from under the gas tank.
The theory is all there, now I need the practice...
I had to find some slack, but it fit just fine with the stock bar and clamps.And did it fit nicely with the clutch cable and all other wiring on the outside of the clocks or?
A bike without a tach is like a dog without a tail. Some might prefer it, but I want to see he engine wagging that needle.
That is an awesome quote. Gave me the widest of grins.A bike without a tach is like a dog without a tail. Some might prefer it, but I want to see he engine wagging that needle.
