Just when you thought you've seen the last installment of the 'Adding a Rev Counter Saga', here I go with a bit more to add.
I was a little irritated, when I noticed that my twin clock arrangement would bounce a bit while riding; and I'd rather have a firmer set-up for the gauges. I was going to create my own mounting bracket and have it milled from billet, but before going that route, I wanted to see what else was available (However, I still may make my own.)
While browsing the Motorrad fische I noticed they offer two possible mounting brackets for use if you add the Rev Counter. The first one which is discussed in length here is plastic and flexes (46638558379), the second one is a cast aluminum piece and is painted black, and is pretty rigid (77318558093).
Both work interchangeably on the Pure, Scrambler, and UGS. I've just swapped my plastic bracket for the cast part, and will report back as soon as I can about its performance, which may be mid March - seeing we got a 13" pile of snow here last Thursday.
They are slightly different in shape. The cast part (on the left) has a steeper angle, and is slightly shorter from where the bracket mounts to the bike - to where the individual buckets attach to the bracket.
