After purchasing a 2017 600mile Pure earlier in the year, I’d decided an Urban/Scrambler on steroids was going to be a better fit, so rather than trading a losing a small fortune, I figured an upgrade was possible for very little cost. Here’s the changes made. Note, the rake on the frames are actually identical between the models, the rake and trail only change because of the longer forks and shock.
Purchased a pair of F800R fork tubes, these are 635mm, 7mm longer than the Scrambler and 10mm longer than Urban. Purchased longer damper rods off ebay (mine were the 1” lower versions). Figured adding 5/8” spacers below the damper rod to get a little extra stroke. Purchased a Pair of RaceTech emulators, drilled out the damper rods and added longer spacers to give 20mm pre-load and assembled with synthetic fork oil. Added a Scrambler fender and fork brace off ebay to complete the front end build.
Before and After Forks below:
Stock Scrambler wheels were also sourced off ebay. The rear rim is a little narrower, and better suited to adventure riding and the front obviously is a 19” compared to the 17” Pure wheel. Brakes, axle etc all interchanged without issue, though I did need to extend the brake hoses.
An adjustable rod end tie bar was fabricated to allow me to figure out the best rear shock to suit the 3+” raised front end lift. Conclusion, was Ohlins BM940 shock normally installed on a R1150GS. This has a length of 383”, which should raise the rear by 3” and keeps the balls of my feet on the ground, whilst maintaining the 61.5 deg rake of a stock Scrambler. Shock is on order as are the high front fender from a KTM and an urban headlight surround. Will add some pics when the parts arrive to finish the work off.
A few other misc changes include a custom aluminum bash plate, a small rev counter, rear seat delete plate, monster long kick stand, and a battery frame to allow for K&N filters, a small tray for mounting a tool box where the old airbox was located. Custom seat mount to allow the aluminum side covers to be eliminated, and finally some aluminum covers for the sides of the seat base, and cover where the intake tube was.
Next project is to build a pannier frame for mounting my Tourtech hard cases, and adventure style tires will complete the build. Once I’ve sold all the parts I’ve changed out, I should be down about $1500 which is a lot less than I would have spent trading for a Scrambler, and I’ve got something a little unique now.
Should be able to post completed build pics once the remaining parts arrive. Hope you like this build.
