1 - 5 of 5 Posts
Hello,
I've had this fitted for a few months now. I put it on a dyno and they said it's running quite rich (104bhp).
He said he can do a custom map using the rapid software for around £175.
Has anyone had this done? I'm tempted to get the My Tuning Bike add on instead.
2016 R Nine T Classic
Hello,
How much are the AFR ?
Yes it is rich, normally the rapid bike will auto adjust to a target AFR which is generally 13.2. This is done by reading the OEM's lambda and targeting 13.2 with a conversion ratio because lambda = 14.7.
It can be a bit off and this is adjusted with the "O2 sens" setting.
If you are planning on installing the My Tuning then it will 100% target 13.2 because the readings are accurate and instant.
FYI: I have the My Tuning and another member has it too and we are both happy with the performance.
1 - 5 of 5 Posts
