I have the stock suspension on my 2018 Urban GS. I want to adjust the rear spring preload and damper, now that I have the two missing hook wrenches. But the instructions in the user manual don't make sense to me.
Step 1 was no problem, I loosened ring 1. As I want to reduce the spring preload, I skipped to step 2, but step 3 says to continue loosening ring 1. I would think that reducing preload would be the opposite of increasing it, so I should do the opposite of step 2. Furthermore, if I did what the book says, and then proceed to step 4, I will just undo what I did and still have the same preload that I started with.
I think that step 3 should read "To reduce the spring preload, turn adjustment ring 2 with the hook wrench in direction B". However, ring 2 is not budging at all. It resists enough to make me question my assumption. Am I right but just too gentle?
