I've never done this myself on a nineT (but have on other bikes)............but I'd say a few minutes work with a Dremel or some other similar type of small grinder will have those pesky DB killers out no problem.
Oh no but it’s better than a nylon cable tie! What you can do also if you’ve a tig with HF start is melt the stainless wire on its own to form a ball or a rain drop however you want to see it then do as I’ve said above with the copper and rest it in the hole then apply heat till it just melts in. If you don’t have a go you’ll never know.I know welding it up was going to be beyond me.... mig on 1.2mm steel is my limit!... what about a stainless cable clamp around the holes...... the thin stainless zip type ones.... then the end cap back on..... this is what I was thinking.... but haven't got to it yet..... I'm making a front rack at the moment.... with 1.2mm tube.... haha.
Why do you want to weld the drill holes up? Unless for aesthetics, and/or you went way larger than a 6mm drill bit, it would be totally unnecessary. Put the end caps back and enjoy those open Akras, - Basta!Upper can was the same but much more stubborn. The SS was eating drill bits alive. So I had to get a new bit and upsize it by one size. This also killed the bit and I think rewelded it again from heat.
I got out the dremel with some tungsten carbide deburring and grinding bits to clean out the holes.
Then let some wd40 sit on the tip facing up to to soak into the crack between the db killer and outer tip.
Came out 5 pulls later.
I’ll have to weld up the holes tomorrow so exhaust doesn’t blow into the caps. View attachment 150363
Pop rivets also have a hole in the middle....Apologies, as I know this thread is over a year old. I just picked up my 2023 and this is the only euro 5 scrambler example I can find online where this modification was done. I like your solution to closing up the holes with the hardware, but is there some reason people aren’t going with a pop rivet to close the holes?
I’ve seen one or two examples where there the open holes have resulted in the “whistle” which I definitely wouldn’t be able to tolerate. From the brief clip on cold start yours didn’t seem to have a whistle even without your hardware installed. Seems like there must be some threshold with hole size to avoid the whistle? Either way, I guess if you started with 11/32 and had to size up and do some clean up on a few holes I assume I could get away with the same. Would love it if I have the option to close up the holes and don’t need to based on a whistle.
Nice job and cheers from a fellow CT local
