1 - 4 of 4 Posts
Roland Sands Valve covers. Can't get off by hand force alone. Is there a special tool? If not what size allen might this be? Id sure like to use a polymer allen as opposed to steel. I don't think allens exist in any other material other than metal, at least I cant find any. Measurement: Without using an inside micrometer I get about 9/16 - .5625in - 14.28mm
Thanks!
If you're worried about marring the finish, a layer of thin tape on a metal hex drive might help. Or, (dangerously), off the top of my head, maybe a layer of thin aluminum sheet inside the socket there with whatever size hex might fit in that.
Just try several Allen keys until you get the tightest fit, then put an extension tube over it for leverage, make sure to turn it the correct way.
Cheers,Ken.
1 - 4 of 4 Posts
