Been doing some servicing & mods on my 2017 R9T Racer over the winter.
The servicing work is irrelevant as it was nothing to do with the problem.
The mods included, full SS Zard exhaust system, an MWR performance filter (road), flapper valve elimination & a Rapid Bike Evo fuelling module. Last year I was having problems and faults due to a RapidBike Easy on the bike, that I didn't know about until later, being wrongly set and a duff knock sensor into the bargain.
When I went to start the bike the other day it would not run on the RHS cylinder, easy to tell, the bike wouldn't idle on its own and after a few minutes the LH pipe was hot the RH virtually cold. The RH would chime in roughly & intermittently when applying larger throttle openings and higher revs. No fault codes thrown up, tried a few times still the same.
The only thing of note was I was using gas from last year
Removed the plugs, which were slightly wet and black, although I've seen a lot worse, also smell of fuel so it was getting gas. Heated the plugs with a gas torch to burn off any carbon and then cleaned the residual up with some emery cloth. Checked all the coils were properly seated, connectors secure and also tested for a spark on the plugs, all was good.
Tried again no change, still no joy on the RH cylinder
Then I went through all the connectors involved with the EVO to ensure nothing was loose or wrong there, all good.
Checked with the GS911 and it confirmed that the RH cylinder was not pulling its weight, the RH Lambda was zero mV almost the whole time the LH around 350-380mV. Put the Rapid Bike software on and tested, checked the maps, all seemed fine and the EVO software was seeing all the parameters, but the RH cylinder steadfastly refused to co-operate
I went to the local petrol station and bought 5 litres of new gas, put that in, after draining off most, but not all of the old gas I'd been using.
Also wondered about how these bikes control air to the cylinders, I still don't know how it works and would love somebody to chime in or give me a link to the ins and outs of it. I'm thinking it must have a butterfly on the TBs but how it's driven I've no clue.............stepper motor?
Prior to starting I reset the TPS by cycling the throttle 3 times with the ignition on then closing and swtiching the igntion off.
With no real hope I tried again and BINGO!! fired right up on both cylinders and idling like a champ.
It could have been the fuel but I very much doubt it as it fired immediately, any bad gas in the fuel system was still in there. I'm 99% certain this was due to the TPS reset, again some info on it would be useful, is it a single sensor or one on each TB?
I've come across bad TPS calibration causing rough running but never heard of it dropping out a cylinder..............perhaps that's a BMW quirk.
Just thought I'd post the problem what I did and ultimately what cured it.
