Scrambler Modification programme
13746 Views 50 Replies 15 Participants Last post by  Silaxe
Well, I thought I would share my journey to make a few changes to my 2019 stereo metallic matt scrambler X.
Bought it in the UK and brought it back to France last summer and after a few months thinking about what to do, I am now ready to proceed.
The general idea is to:
  • put a single seat
  • shorten the back
  • put the license plate on a GS mudguard
  • change the blinkers
  • remove the airbox
  • change the gas cap
  • and put handlebar mirrors.
There are surely going to be other mods along the way as I am sure it will be hard to resist the urge ?.
The first pic is of the bike as it stand today.
128711
Yes I have the knobby tyres and they are loud (above 70 km/h the tyres are actually louder than the exhaust...) but they do give a nice look to the bike. On dry surface I got used to banking in turns as much as with road tyres but I have not quite tried them on the wet.
There are actually a few modifications made to the bike already although they are quite uncuspicuous:
  • I have put the OEM tankbelt. While I do not plan on having a tank bag, the belt looks good and it does protect the tank from scratching near the seat. I am just a bit disappointed by the fact the hole for the gas cap is not very round but rather ovale...
  • I have put Wunderlich foot protectors to avoid getting my feet drenched should I get caught by the rain. I have had this on all my bikes and it really makes a difference. I have a post on this specifically for those who may be interested.
  • I have also put a brake pedal enlarger. I am actually not so interested in enlarging the pedal but it does raise the surface in contact with your foot a bit as I find the pedal way too low.
Voila.
1 - 20 of 51 Posts
3
I have ordered most parts by now but many are yet to arrive.
The first thing I started working on is the GS mudguard with a Rizoma license plate holder.
I am quite happy with the way it has turned out after scratching my head as to how to attach the plate to the guard.
Product Electronic device Armrest
Auto part Technology Electronic device Gun
I still have to see how best to route the cable through the arm of the mudguard.
Next week end I will probably work on what will come in place of the diving board at the back.
Will post some pics once I have something to show...
Following this as these are more or less my exact plans.
How much was the mudguard as I've seen them on ebay from China.
Hi Cabby,
Bought the mudguard from a site in Germany selling OEM parts for 138 euros.
You will also need other parts (spacer, bolts, ...) and this will set you back another 32 euros.
Hi Silaxe! Nice plans and great idea for the license plate mount!!!
Will post some picks once I have something to show...
Hey Silaxe, Could you let me know the parts and the part numbers you bought for this? I am trying for a similar set up as yours.
Thanks,
8
Thanks Rems.
Hi coron2u,
Sure.
First you will need the BMW Parts for the GS Mudguard:
  • Mudguard GS 1200 - Part # 46 62 7 682 884
  • Mudguard mount bracket - Part # 46 62 7 671 618
  • Screw for rear mudguard M6x65 - Part # 46 62 7 688 883
  • Screw m6x20 - Part # 07 12 9 904 073
  • Rear mudguard washer - Part # 46 62 8 543 238
The license plate holder I chose is the Rizoma ref PT081B in 100x162 mm.
It comes with a LED light but without a reflector, so you may need to ask your reseller to order one too although I have no reference for this part.
Then you will need to buy the bits and pieces to put the mudguard and the license plate holder together:
  • 4x Black aluminium countersunk head bolts M6 x 25mm
  • 4x Plastic 10mm long x 10mm ext diameter x 6mm int diameter spacers
  • 4x Plastic M6 washers
  • 4x Rubber well nuts
  • 1x Rubber pass through cable grommet - 5mm int diameter for a 3mm wall thickness
For the tools, I used a 13mm wood drill bit (for the well nuts) and an 8mm metal drill bit (for the pass through grommet). Before drilling with the wood drill bit a did a pre hole with a 3mm metal bit.
I also used an x-acto knife to clean the holes' edges after the drilling was done.
You will need to make a template for the location of the holes and tape it to the mudguard to precisely drill it.
I attach a few pictures that will hopefully illustrate the process and the needed parts.
I still need to work out the routing of the electric cable to the light.
Let me know if you need more info.
Fastener Auto part Screw Nut Hardware accessory
Auto part
Auto part Wheel
Material property Auto part
Material property Paper Paper product
Technology Electronic device Wire
Metal
Automotive wheel system Automotive tire Auto part Rim Wheel
Reactions: 2
Thanks Rems.
Hi coron2u,
Sure.
View attachment 128769 View attachment 128770 View attachment 128771 View attachment 128772
View attachment 128774 View attachment 128773 View attachment 128775 View attachment 128776
Thanks a lot bud - I'll try to source the parts for just the mud guard for right now. :)
I have been asked where to get the small hardware to put the mudguard and the license plate holder together so here it goes. Each list item is a link to the site where you can find the item.
For the last one I actually bought the grommets from a site called Distronic but somehow it has been in maintenance for the last few days so I have put an alternative.
Hope this helps - Cheers.
So, after a little break I have received most of the parts needed and will start working on the bike!!
So far I have the following:
  • BMW Single seat + BMW painted seat cover
  • BMW black cylinder heads
  • Unit Garage handlebar mirrors
  • BMW NineT Racer handlebar clamps (neater than leaving the ones with a thread for the original mirrors)
  • Kellermann Bullet 1000 PL for the front and Bullet 1000 DF for the back
  • Rizoma under tail cover ZBW048B
  • Rizoma electric wiring EE104-01
  • BMW GS Mudguard + Rizoma PT081B license plate holder
  • Luis Moto battery tray to remove the airbox
  • K&N RE-0960 filter
  • K&N 62-1340 breather filter
  • Wunderlich right side bag
I am actually still waiting for the airbox removal "kit" and for the gaz tank cap.
I have plenty of bits and pieces to put everything together such as cables, plugs, caps, etc so do not hesitate to ask if you have questions.
I attach a couple of pictures illustrating what needs to get on the bike!!
Art
Illustration Art
Cheers - Silaxe
Reactions: 3
So, we're 8 hours later... I'm sure everything is mounted now, not ? Can we see the result ? ;)
Yes, I know, I'm not that patient ?
Nice parts ? Can't wait to see it assemblied ?
Hi M&M,
I wish ?
Will take it slowly as I want a nice and clean set-up.
I am a bit daunted by the airbox removal I must confess!!
Will post as I progress.
So... have not posted much as I have not progressed much (understatement...).
I keep on realising I am missing a bit
For instance I want to put rubber nut covers for the blinkers for a better finish as the Kellermann come without it so ordered a set of these (but cannot solder anything in the meantime...)
Did manage to get the battery relocation kit from Luismoto - delivery was fast and it looks pretty good. Foam padding may be a bit thin though so will have to see if I mod this. Also wonder if I can reuse the original battery retaining metal strap rather than the one from Luismoto as it looks better.
Also very excited with my preorder of the gas tank cap that @Florian Gounaud has designed. I initially thought of the Monza model but wanted one that locks and especially one that has a better design!!
Finally got a bike-lift stand to raise the back of the bike and work steadily.
Voilà - That’s all I can update for now
Have a great WE.
10
So here we are, I have now received all the bits and pieces but am no longer with my bike :cry: as I have relocated away from Paris in the context of the current crisis. Anyhow, managed to do a few things before I had to leave and here is my progress below. It is a bit long but hey since I cannot fix or ride my bike, I enjoy writing about it :).
GS Mudguard and License plate holder
A bit of info updating what was written above. Getting al the parts right is actually a pain as there is no manual as to what you end up needing.
I received the reflector bracket and the reflector after a lot of waiting.
There are 2 shapes for the bracket with the same reference (PT533-05-VE-B) ?!
And there are 2 references for the reflector:
- EE141-01 for the one with round corners
- EE045-01 for the one with square corners
While I prefer the bracket which does not come forward, the one I received actually seems to work better as it gives more room behind it for the nut that ties the reflector... I also replaced the nut with a black one.
Now that I have plenty of time before I attach anything to the bike I'll see if I manage to order the other version of the bracket.
Buckle Number Metal
Material property Technology Auto part Shoe
Line Auto part Automotive window part
Line Diagram Technology
What is tricky is the fact that the two little bolts holding the reflector bracket to the plate holder are right at the level of where the mudguard protrudes. So when I initially put everything together and started shaking and banging the whole set-up to see how it held together, the bolts were hitting the mudguard :rolleyes:.
So I removed the washers and shortened the tiny bolts so they would come flush on the other side, went for slightly longer spacers too, 11mm for the top and bottom ones and 12mm for the two on the sides and put two washers on the bottom bolt. Note that compared to what was written above, I changed the bolts from 25mm to 30mm.
Now the whole set-up no longer rattles when I abuse it although let's see if this is the case once it is on the bike.
Technology Electronic device Machine
Bumper Automotive exterior Auto part
On the inside I finally found a way to attach and route the plate light cable.
I used bowden cable clips (ref 51 21 7 040 546) which I shortened and hot glued to the mudguard.
I would have liked to pass the cable fully through the arm of the guard but unfortunately there is not enough space inside on the whole length so I made a small opening where it becomes large enough. The material is extremely hard and the best way was to initially drill and then clean up the opening with a cutter.
The outcome is quite clean and the cable is well protected.
Automotive exterior Auto part Bumper Windshield Automotive window part
Pliers Tool Tongue-and-groove pliers
I used an indicator connector for the end of the cable and prepared a 125cm cable to connect the license plate light to the tail tidy set-up. The cable will follow the side arm along the brake line and then into the underseat tray.
Cable Wire Technology Electronic device Hose
More info on the next post.
Tail Tidy
The next thing I managed to (almost) finish is my tail tidy.
I have used the Rizoma under tail cover, Kellermann Bullet 1000 DF black indicators and the Rizoma electric wiring (Ref EE104-01). I also bought a rear wiring harness from BMW (ref 61 11 8 548 705) to get everything ready while I still used my bike.
Still life photography Black-and-white Photography Monochrome Music
There are plenty of bits and pieces needed to have a "tidy" set up.
I got BMW indicator connectors (ref 61 12 7 699 594), rubber nut covers from Rizoma (ref RB-084), cable sheath, special zip ties that attach to the little "winglets" (BMW ref 34 32 7 708 473), rubber plugs for the unneeded holes and a plastic bracket (ref 61 13 8 365 536) to clip the Rizoma connector for the brake, position and plate lights.
I have soldered all cables and used shrink tubing to make things clean. I have also used a black fabric tape where I was worried about chaffing (ref 83 30 0 402 345).
Photography Auto part Metal
Tool Technology Cutting tool Metalworking hand tool Gun
I have tested the set-up and it works!! and no error lights.
Once I have everything finalised it will be plug and play.
More info in the next post.
Airbox / Intake silencer elimination
This is mostly prep work as the main thing that needs to happen is the removal of the airbox.
I will cut it as I have no intention do disassemble the bike.
I finally decided to get a power tool to do that and bought a Proxxon long neck mini grinder.
Before I cut through it though I intend to Dyno my bike in stock configuration and with the filters mounted on the intakes. Some said they'd do it but I have not found any results anywhere :cautious:.
The main work was preparing the temperature sensor to be able to relocate it in the left filter. I have followed @TiM81 's post and he provided much needed advice to get to the right result. I have published what I have done on his thread but will consolidate here.
The sensor is a bit bulky and needs to be ground to become circular in shape. I cut off the excess plastic and then protected the tip and inserted it in my wireless drill to sand it at high speed.
I then painted it for a better finish.
Product Auto part Automotive ignition part Automotive window part Automotive engine part
Tool Tool accessory
I have selected K&N filters ref RE-0960. I like that model as the cap is matt black with the K&N logo.
This is the way the sensor will be inserted in the filter
Auto part Metal Cylinder
Steel Pipe Wheel Metal
Wheel Metal
The wall of the filter is very thick and the groove (where the green o-ring sits initially) needs to be widened from 3.5 to 6mm for the notch to sit properly on the other side of the wall.
For reference, the tip of the sensor is 9mm in diameter and the groove falls to 8mm in diameter. The notch is grinded down from 13mm to 10mm.
The hole drilled is 8.5/9mm although I used a 10mm drill bit to make it. It is placed 6.5mm from the edge of the flange so that the whole sensor sits fine against the flange once inserted in the filter.
The next thing I prepared is the extension of the crankcase breather hose with a filter at the end.
I used another original BMW hose (ref 11 15 7 712 578) and a couple of connectors (22-22mm and 22-16mm).
The filter is a K&N ref 62-1340.
Microphone Tool accessory Cylinder Screw
Tool accessory Tool
The battery relocation bracket is from Luismoto. I prefer it to the other options as it is quite hidden once in place.
Technology Room Electronic device
Room Electronics Audio equipment Technology Electronic instrument
The foam padding seems a bit flimsy and the nuts and bolts could be better. I replaced them with black ones with a flange. (got them from car bolts.co.uk). I may also put some rubber washer between the bracket and the bike's frame if the clearance permits it.
Black Stainless Steel Socket Button Flange Screws Fairing Bolt
Non Serrated Flange Nuts Black Stainless Steel
Voila - Not much more to add at this stage. Will update soon hopefully...
Reactions: 4
Very nice work - looks like factory quality.
Not like the usual "that'll do" efforts I make.
Very interesting, keep us posted!
Nice work,
Thanks for sharing, it's gonna help me a lot because I want to remove that air box too.
Do you plan to do something for the engine after the removal of the air box? like a power commander ECU or something?
1 - 20 of 51 Posts
