When cold, does it come straight from the charger?
Maybe the dynamo is faulty?
I don't keep the bike on a charger because I ride at least once every week.When cold, does it come straight from the charger?
I never replaced the alternator.Start by measuring the Alterntor (Dynamo) like @Chopper_Bob mentioned. Does it charge the battery?
A battery will gain some of it's "Power" back when you leave it un-used for a while. This would explain the situation if you turning the bike off; waiting 10-15 mins and it then starting again.
I see you replaced the battery and starter. But this still does not warrant anything. Batteries can go bad within months. Measure to know.. can be done with a cheap multimeter.
Why did you replace the alternator by the way?
If not the battery/alternator; could also be a vaccuum problem.. But then it should not happen after a gas stop since you open the gastank to do it..
My thoughts too, I'd be checking connections at battery, starter etc, perhaps undo them, clean with a scotchbrite pad and then re-connect.Since it's starting fine cold, I'd look at he wiring from the battery to the starter and the starter to ground first. All of those were loosened recently and heat may be making them a bit loose from expansion. Sightly loose connections might handle the current when cooler because electricity flows better when colder.
Yes, I will do that today.Can you check the voltage on your display?
Yes, but dealers employ technicians.Any Mechanic with some kind of functioning brain should know all this.
Im not even a mechanic.
Ah yes; if computer says it's fine.. it 100% is.Yes, but dealers employ technicians.
Mechanic and Technician are not the same. Learned that the hard way lol
