This weekend I installed a handful of mods onto my 2021 Pure.
Let me know what you guys think and if you have any questions! I don't wrench on vehicles too much, so I was a bit apprehensive about all of this, but all-in-all it was an easy feat (except for my on-going CANBUS/LED issues lol).
STOCK (only mod prior are the Classic Raisch, Motogadget underbar mirrors):
Wünderlich SIXDAYS tail:
Hookie license plate bracket:
Rizoma Iride multifunction rear turn signals:
Garmin Zūmo 396 LMT-S GPS:
- Rizoma Iride S multifunction rear turn signals
- There's a thread where someone hacked up the factory harness—don't do that. Do yourself a favor and buy Rizoma EE104-01 harness that plugs into the Euro plug. It's plug and play, no cutting of any harnesses, no changing out of the bullet plugs, nothing. You'll still need two turn signal connectors (EE078H). No issues installing these!
- Wünderlich SIXDAYS tail
- I chose this tail tidy because of how it "completes" the Passenger Pillion...but boy oh boy what an animal this was to install. Provided is a rigid u-frame that's supposed to slot into the rear of the Passenger Pillion. However, it was slightly wider than the Passenger Pillion and required me to put all my might to try and squeeze it into place. After what seemed like an eternity I mustered enough strength to snap it into place using all my weight. I was not able to successfully tap this taillight into the Rizoma harness...not sure where to begin. I'm a wiring dunce, so I know nothing about resistors, why they're not working, why they're throwing codes, etc. Besides that, install was simple and straightforward.
- Hookie license plate bracket
- Love the simplicity of the bracket. I bought an aluminum, license plate blank from amazon as the mounting plate for the License Plate itself. Only issue here was the hardware was too long/washer spacers weren't long enough. Not to fret I ran to Lowes and purchased washer spacers to add to it to make it work. I however, couldn't figure out how to get my license plate lights to work (again wiring dunce). They flashed once then stayed off and threw a CANBUS code.
- Hardwired my Garmin Zūmo 396 LMT-S GPS
- After following a gentleman's directions on the BMW MOA facebook group, the hardwire wasn't working...I came to the forums and it turns out his instructions were BACKWARDS and I was wiring the live wire to the ground and vice versa. After swapping connections and turning the bike on the GPS turned on and I was a happy camper. I'll be installing an M8 RAM mount into the handlebar clamps for the GPS bracket — will update the thread when I do.
