Easy battery replacement
4K views 13 replies 8 participants last post by  Dirtmerchant
I was wondering if it's possible to change the battery by raising the rear of the tank instead of removing it fully? Not sure if anyone has tried it or if its possible. Seems like a pain to have to fully remove the tank.
#6 ·
Agree with the two posts above.......but would add to be very careful when tilting/pivoting the tank forward, as it's very easy to damage the ignition switch housing, or the paintwork on the tank area near to it........or on the top yolk/handlebar clamps too. A thick bath towel or leather jacket to wrap around and cover the tank to help protect the paintwork is worth doing for extra peace of mind too.
Deffo easier and safer to have an assistant lift and hold the (preferably empty) tank whilst you swap over the batts.
#8 ·
@judmusty44 I am on the same path as well... I was waiting for some good weather to empty the tank. If you end up trying this method would you mind posting a few pics or detailing your experience?
[/QUOTE
Will do, not sure if I definitely need one yet but first ride out the other day and it only just started :-(
