Don´t mean to start a discussion whether you NEED floating rotors, I was just looking to see what is out there for the R nineT. (Was looking at cars actually but got carried away)
The R nineT shares the OEM rotor with
According to OPP Racing the Brembo 208973751 fits the R nineT, it is Brembos Supersport discs. Same braking surface width of 34mm, slightly thicker at 5.5mm compared to OEM 4.5mm, no adjustments necessary.
Brembo High Performance Front Floating Rotor Kit (320mm) - OPPRACING Products
Also this UK company lists them as compatible with the HP2.
SPP.033.HPKSS.BR Brembo HPK SuperSport Discs, Brakes
But, if the fitment is the same as the BMW S1000R 2014-2015 and BMW S1000RR 2009-2015 listed by OPP racing, there are more possibilities.
Alpha racing in Germany alpha Racing Performance Parts, Electronics & ECU Tuning- BMW S1000RR
- K52 (R 1200 RT) (01/2013 — )
- K53 (R 1200 R) (11/2013 — )
- K54 (R 1200 RS) (06/2014 — )
- K21 (R nineT) (01/2013 — )
- K73 (F 800 R) (11/2013 — )
- K49 (S 1000 XR) (05/2014 — )
