81 - 100 of 164 Posts
Discussion starter · #81 ·
... haven't found a suitable 90 or 47 deg valve yet. I bought a pair of valves from eBay, only to find (during tire change) that our R9T's rims require a longer valve stem to get past the nobbly bits where the spoke-heads recess into the rim internally. Tried to fit them, they were only a few smidgens too short ... haven't been seriously looking since, but got myself a tire-inflator-ball-chuck instead. Fitted to the inflator tip - works well to get into tricky tight spots.
NEW 1 4 Inch Ball Chuck Brass Tire Inflator AIR Line Compressor Tank Valve | eBay
btw, this Tire Plugger I ordered from Sierra BMW a few years back works amazingly well. Even fixed my 4WD tire yesterday.... makes me happier than the idea of roadside-pulling-off-of-wheels-&-tires-to-get-a-tube-repair-happening ever could .... just sayin' hehe
>>> 8 minute roadside repair: 4wd punctured (picked up a timber screw), jacked up to take weight off, removed valve to completely deflate tire, remove screw>ream out puncture hole>insert rubber plug into tool>plug hole>inflate tire>remove jack>done <<< great stuff, they make it sooooo easy!
1075- BMW R1150GS- Sierra BMW Online- Stop & Go The Tire Plugger - Tubeless Motorcycle Tire Repair Kit
Looking good so far, did you remove the tyres yourself? I've got to get my arse into gear and have a go myself while winter is here...
Thanks, these wheels are a spare set I bought from honored member NeightT, w/o the tires.
Front done and looks good, should work? I skipped the Outex hologram sticker part, I hope that doesn't jinx me!
Have to keep putting an alternative to Outex out there. Cheaper, faster and it works. Total cost about $30/wheel including material, tire dismount, mount and balance. Done over a weekend.
KTM 990 Tubeless - cyb
I'm going down that route, just ordered all the necessary stuff off Amazon and eBay and can't wait to make a start....:D
Not good news to report about my Outex kit, the rear held good for about 2 weeks and now its losing about 2 psi / day, the front is also going down too at about 1 psi / day. I haven't actually ridden the bike with the Outex kit fitted yet. Going to put the wheels in some water tomorrow see where they are leaking :(
Huntsman
The 3 bar pressure will increase equally in all directions as you ride because the heat of the tires will heat the compressed air and the pressure increase during riding-equally, in all directions inside the tire, and will not be affected by gravity.
Both front and rear are leaking in exactly the same place, 1 spoke from valve roughly where the joint in the tape is which I cut at an angle and put an final patch over the joint as per the instructions. With hindsight I would have sealed the spoke nipples as per the DIY fix posted on here beforehand, anyway tubes are going back in (over the outex) as lost the will with it now, did consider some tubeless spoked rims but I cannot justify the money.
Sorry to hear that...
Before you go back to tubes I would go with seal-all on all spokes then tape with 3m industrial foam adhesive tape. Got the tape from Amazon. Did my rear tire with these two and have not lost a pound of air in 3 months. Total cost $30 and have well over enough to for the front wheel when the day comes. Just my .02
Billywhizzz you don't have to spend a fortune to go spoke less and more important tubeless.A few weeks ago I purchased a set of r1200r black cast wheels for just under £500, the rear had never had a tyre fitted and the front was in 95% condition, £5 for new front seals and £15 to swap tyres over from spoked wheels,bargain as far as I'm concerned and they look and feel great.
hi, it had crossed my mind but I do like the look of the spoke wheels, do you have a pic of the wheels fitted? I think the same front wheel is used on many BMWs, rear less so. You got them at a good price!
I think these are the same style of wheel as fitted to my K1300R with the curved spokes, they are nice wheels.
Hi guys!
My outex in rear wheel has broken in two spokes :(
Does anyone has the same problem? How to fix?
Sorry... images.
Its the tape splitting.
Grinding?
Looking at your pictures I'd say you didn't grind enough off the spoke heads. They need to be almost flat so the tape doesn't stretch.
Here is my rear wheel. This is how I did the front which is holding steady. Once the tire was mounted I put 50psi in it and warmed it up to 110f for 10 to 15 minute, I figured the heat would help? Outex says you can use patches of leftover tape for repairs.
DR
Discussion starter · #97 ·
hmm, sorry to hear about your Outex mishap. Mine's still going strong. 12000 km, no leaking. Not even during weeks of being parked up. I've become a bit OCD when it comes to checking tire pressures (after doing the Outex conversion) just to be sure to be sure to be sure ... but yep, it's doing exactly what it promised. I hope it'll last for a few years yet ...
Good luck with the project!
Take your time; follow the instructions. No need to grind, no tape, just some time and a couple of tubes of sealant. You will be tempted to hurry but best results come with patience and letting each application of sealant cure per the instructions before another application.;)
Just finished doing the KTM 990 tubeless conversion , I've only done the rear so far, everything went as per instructions, I did find it a bit of an effort getting the Metz of the rim until I warmed the tyre up with a heat gun then it came of the rim easy. Looking forward to riding my bike to see if it maintains the checked air pressure in the morning...fingers crossed.
Haven't visited this forum for a while, saw your post and thought I would let you know that my R9 has sat for four weeks (other bikes to ride) and lost 1-2 psi which is less a loss than I saw with tubes. If you followed instructions and used the specified materials, you should see the same results.:eek:ccasion14:
Discussion starter · #100 ·
two and a half years later
... Rainy season and winter and busy with projects meant bike rested for about 3 months. Checking the pressures yesterday showed both tires only dropped 5 psi / 0.34474 bar. Pretty good result for OUTEX treatment, I thought.
