Wrapping the NineT in vinyl - little guide
189K views 208 replies 75 participants last post by  arfingdog
#1 · (Edited)
Hey guys... I had some private messages asking how I wrapped the front end with vinyl.
I thought of putting the answer into a post so others can get an idea as well.
The top bit is simply a rectangular shape.
I just measured it and cut a piece of vinyl. I used a bit of soap water to apply the vinyl. As soon as you pull the vinyl off it's carrier spray the soapwater on its back, on the sticky side. This prevents it from drawing dust particles and you can move it around a little while applying it to the bike. When you are happy with the way it sits you squeeze the water out with a soft cloth. Don't get inpatient when doing that... take your time. Once the soap water is gone the sticker will grip and over night it'll completely dry. You can use a heat-gun to speed up the process a little... and if it fails the first time, pull the vinyl off and try again... absolutely nothing wrong with trying several times. :)
Let it overlap where you are least likely to see the seam.
For the bottom part you probably have to make little strips for where the fork is thicker. I did remove the front fender to have a bit more space wrapping the strips around. If you can remove the front wheel it'll be perfect. See below how I have done it... not the cleanest work I've done but as soon as you step half a meter away from the bike you can't see the cuts.
With these bits I also used a heat-gun set to 150C. But it'll depend on which type of vinyl you get.
Questions? :eek:
Cheers,
M
#92 ·
frame wrap?
Hey Marc,
Would it be possible to wrap the frame without disassembly? Do you think it would look bad with all the seams etc.
Also, I never wrapped anything so consider that in your answer if you don't mind.
Thanks,
David
Reactions: Shado
#93 ·
Posting up here as well (I've also dropped these pics in Owners Photos).
Green and White Vinyl on tank, hump and front fender.
Black Vinyl on the side 'nine t' bit.
I got a place in Birmingham (UK) to do it for me as it was a bit more complex than I imagined - now i've seen where they make the cuts though I might be inclined to try it myself.
#94 ·
I have also experimented with vinyl wrap but not the flat one, but the one with shapes and some surface finishings.
For example, next is what used to be my front cover engine with carbon fiber like vinyl. It's is not hydro dipping, it's vinyl and I think is better as the finishings can be touched and can be seen.
Vinyl comes in many other motives, so check around.
http://www.ninetowners.com/forum/showthread.php?t=67017
Front engine cover MODS (alternator cover)
Saludos desde Bogotá, Colombia
#96 ·
ordered the 3M vinyl, gave it a try and decided to let the pros do it. i think with more patience, better cuts, i may have been able to conquer the lower part of the fork leg, but i couldn't. the top tube(s) weren't hard at all.
the finished product,
#97 ·
Norm came around...
Well... Norm came over this afternoon.
Bored as you can be with a 3 months old baby sleeping upstairs and the woman of the house off to Yoga while all the dishes waiting to be washed... we realized that Norm's 2x1.4 meter roll of vinyl was still at the back of the garage...
An hour later our Ts are turning into twins more and more... :D
:eek:
#104 ·
Don't want to thread jack but IMHO if you guys out there are going to try vinyl wraps can I give a few tips...
3m 180cv3 is the best wrap vinyl
Clean parts thoroughly with prep sol or alcohol
Most wrap vinyl needs to be post heated to 100 deg to give it a new memory and hold its new shape.
If you don't do this it will eventually fail and lift off severe curves.
And before you ask 25 years in the business
#107 ·
^^^^ Silly question - but is that 100 deg F or C?
C, Mate
Has anyone thought of wrapping the whole tank with a clear vinyl to protect the paint, rather than putting tank protectors in high contact rubbing zones?
If so how much did it cost and what product did you use.
Good quality wrap film is very thin, I think for the expense and frustration in wrapping a tank I would use tank pads for protection.
#121 ·
Now I must have missed something...
I'm planning on doing the brused alu side panels of the tank to black this weekend.
So,
1. Remove the wrapping from its carrier and spray with soapy water
2. Apply to bike, move around and remove luft bubbles
3. Here is where I'm lost. How do I cut the wrapping around the edges of the sidepanel of the tank? Do you guys use a box knife or something like that? I'm thinking of the risk of scratching it
#122 ·
We use what is called knife less tape which you stick on in the shape you want cover with car wrap vinyl, find the end of the tape and pull the Teflon string out from the tape it actually cuts the vinyl to shape for you. You can also use a scalpel and carefully cut through only the vinyl and not scratch the paint but it takes a bit of practice.
