256K views 471 replies 191 participants last post by  BavarianPonoWerks
I tried charging my R9T battery using a cheap battery tender with a adaptor plug into the aux socket, it wouldn't work, I tried turn on the ignition and off, it worked for 5 min then off, then I found this charger on the website TecMate OptiMate 4 Dual Program Battery Charger for BMW CANbus - RevZilla.
It seems that the charger must be compatible with the can bus system, is this the right charger? Do I have to buy one from the dealer? Any one has a good suggestion, thanks
#40 ·
Any decent trickle charger with a battery monitor can be 'hard wired' directly to negative battery terminal (black) which nimble fingers can reach by just undoing the lower tank bolt and propping up tank with a suitable wedge thingo (rolled up welding glove), and added to the positive terminals (red) - which are at the front tabs for seat. A pair of pliers and 2 suitable round terminals is all that's needed. I already had 2 chargers from previous bikes, as well as keeping it interchangeable for all my rides. Has worked well for over 7 years ...
(never used to worry much about battery maintenance until a near empty battery caused the frying of the starter relay on my K100. The mechanic explained that the charge was enough to crank the starter but then dropped off and caused the contacts to fuse. Expensive relay to replace. I was too slow on the uptake - had to do it twice :eek: )
since then I use these ones, it's a fused unit: Projecta Charge Maintain AC150 Trickle Battery Charger Motorbike 12V JET SKI | eBay
#41 ·
Hi,
I have been meaning to ask.
what kind of battery do we have in this ride.
One of these days I have to read the manuel but for now I figured I would ask if it is a
Sealed lead, or sealed lithium, gel?, anything, etc. ( Boy do I hope its sealed) I havent even thought about this simple maintenance
#42 ·
Because I already own two other CTEK chargers for my cars, I've bought the small CTEK XS 0.8 for the 9T and it works great.
XS 0.8
The only thing to be aware is that for the 9T to recognize the charger, you first have to turn on the ignition before connecting the charger. I believe that would be the case for all chargers.
#53 ·
lacking the right plug (ordered from ebay china for $2) I just now took the seats off, unscrewed the two torx screws holding the (+) to the metal plate, clipped one alligator clip onto the frame and the other onto the battery and I'm using a small (1A) car lead acid trickle charger.
Why does the manual say NOT to charge the battery in-situ? that it must be disconnected first. That isn't normally a problem for cars. Wondering if this is just cover-their-ass language or there is a real reason for it.
#64 ·
#65 ·
Charging Via. Built-in port
DOES NOT WORK.
I have to apologize for my previous incorrect statement. Evidently it does not allow for charging after its 60 seconds delay is up. I was too quick to glance at the charger, see its doing its job and run away. Oops!
So, regardless of what it says in the manual - Built in 12v port can NOT be used for charging.
