201 - 209 of 209 Posts
is heat required to manipulate the vinyl? If so, How Is this accomplished as it is a gas tank?
You do pretty much need heat...I used a heat gun on low. You aren't putting heat on the tank, just blowing hot air on the vinyl to make it more pliable as you apply it. In some situations you need to heat it a bit on the tank, but you aren't heating the actual tank up much at all.
