TecMATE Optimate4 without CAN-bus for R9T battery charging
As the nights are starting to draw in, I have started to think/plan for winter hibination (the bike not me
) and keeping the bike battery on charge sprang to mind.
I already have an 'original' tecMATE Optimate4 (without the CAN-bus option/setting) battery charger and would like to use it with the R9T.
Being a 'good' forum member 0
I firstly did a word search and found the respective (merged) long thread full of invaluable information already posted by numerous members, thanks to all postings/information!
I read/understand that it is possible to 'directly' connect the battery charger to the battery via the battery tender/pigtail (without having to switch the bike battery on) and hide the connector end around the air intake, but if possible I would like to use the 12V DIN socket solution.
@richrox986 wrote that the Optimate4 (without CAN-bus) did not function in the 12 V DIN connector TM95 purchased via Amazon (
) and returned the adaptor/connector.
@Dodo wrote that it should work (via the 12V socket) if the bike is initially switched on before the battery charger is connected, to make the hand-shake and then switch off the bike.
and therefore (finally) I come to my question......
Did
@richrox986 (or anyone else) try the connect the Optimate4 (without CAN-bus option) with the DIN connector (TM95) to the 12V socket with the bike initially switched on? And if so did the connection handshake/work for longer than 1 minute and/or when the bike was then turned off I.e. Did the handshake retain the power to enable charging to take place with the Optimate4??
If so I will gladly buy the DIN Optimate connector TM95 from Amazon as it would be the most elegant/practical solution, otherwise I will battery tender my existing charger to the battery as nicely described in detail within the
@SlowDad thread posting.
Hoping someone can 'shed some light' or should that be power to my conundrum....
This is their response, interesting as there are others using the Optimate 4?
"Hi there
Sorry to hear about this. If you have a Canbus on your bike that requires the ignition switch on then no battery charger will work with it off sorry.
You are more than welcome to return"
Because I already own two other CTEK chargers for my cars, I've boug ht the small CTEK XS 0.8 for the 9T and it works great.
XS 0.8
The only thing to be aware is that for the 9T to recognize the charger, you first have to turn on the ignition before connecting the charger. I believe that would be the case for all chargers.
Turn on the ignition first time before connecting the charger for the 9T recognize the charger.
Sorry, I haven't read the replies to my posting where I said you have to turn on the ignition for the R9T to recognize the CTEK charger earlier.
It appears that some forum members have wrongly assumed that I've also implied leaving the ignition on during charging as well. That's not true.
Once the two ends handshake (i.e. R9T recognizes the CTEK charger), you can turn the ignition off.
Thought I should clarify that for the record.
